  • 1.  clean feed using the media 1
    Posted 02-02-2012 20:13
    Les I have a clip for replay in the media 1 and I need that it appears in the clean feed output when I hit run, I am using Clean Feed output but in that output the clip do not appear it only appears in the program them let me know what I have to do to solve this.
  • 2.  RE: clean feed using the media 1
    Posted 02-02-2012 20:38
    Okay,
    we will need more info here. Media Store 1 is "located" where on the PGM output -- i.e. which keyer layer?
    To define your clean feed go into the system menu and Clean Feed (middle knob of first menu) clicking on the knob toggles between which MLE you are adjusting -- each MLE has it's own Clean feed. While turning the knob adjust which Keyer you are taking the Clean Feed from before. So when you see M1:K1 this means that MLE 1 will have all of the Keyers stripped from the MLE.
  • 3.  RE: clean feed using the media 1
    Posted 02-02-2012 23:37
    I apologize , I use the Media 2 as upstream them I need that only the clip that is in the Media 2 appears in the clean feed output as a key, only that
  • 4.  RE: clean feed using the media 1
    Posted 02-03-2012 02:32
    So are you saying you are doing this as a media wipe transition? Or are you using a Keyer to layer the clip?
    If it is a media wipe the system is layering based on your selection in the transition area. I will look at this tomorrow but I don't think this will be on the CF. Will update any info in the morning.
  • 5.  RE: clean feed using the media 1
    Posted 02-03-2012 23:59
    There is any update in the Clean feed and media Issue that I have, let me know
  • 6.  RE: clean feed using the media 1
    Posted 02-04-2012 00:27
    I was not able to get in front of a Carbonite today. I will be in front of one on Monday though and should be able to look into then.
  • 7.  RE: clean feed using the media 1
    Posted 02-07-2012 18:48
    So the Media Wipe layers into the Keyers. So if I have my clean feed set to before K1 then I will never see the Media Wipe on the CF. If I set it too Before K2 then I will see the media wipe on CF if I am only performing a MediaWipe on the BKGD. As soon as I add a keyer to the transition it will be lost.
    If the CF is before K3 then I can have BKGD+K1 in the Media Wipe transition and still have it seen on CF. As soon as K2 or higher is added to the transition you will loose the Media Wipe on the CF.
