  • 1.  Positioner module and log.tar file
    Posted 10-11-2013 12:39
    Hello Les it is Kenan ;
    I work for TRT Corporation in Turkey. We use Vision QMD-X switcher V12.1d version. In which situations should I use log.tar file . Secondly , we're having trouble about using the positioner module. Altough we did all the calibration for positioner module it has'nt work properly. Is the problem in the positioner module or in the somewhere else? How can I understand the problem ?
  • 2.  RE: Positioner module and log.tar file
    Posted 10-11-2013 14:17
    Hi Kenan,
    Sounds like you need to call tech support and sort out what is wrong with the positioner. You can call them at 613-652-4886 or email techsupport@rossvideo.com
    It sounds like if the positioner has been calibrated but not working then it may have failed. You also don't list what the behaviour is. Sometimes taking a video on your phone of the behaviour then sending that with your request to techsupport can help them trouble shoot that for you.
    As for the Log files -- you can use those to send to techsupport when your having issues with the switcher and they request the logs to help them look through if the issue requires that extra details.
    #Vision
