Hey little Tip!
Did you know you can actually name the folders! set0-set9 are just a hardcoded name that the system uses but it will recognize folder names that user give as well. So if you have a USB that you already saved some shows to that is fine you can rename them.
First either FTP to the system or just plug the usb into your computer.
Now navigate the to the switcher/sets folder to find your current saved show setup file folders -- inside of each is the personality, installation, memories and custom control files.
If you rename the folder i.e.-- set0 to Hockey -- now when you go to Save or Load you will see that Set0 is now empty and a new folder is available -- Hockey.
You can also just create a bunch of empty folders with different names and they will also now become available locations for storing show setups.
