  • 1.  Resetting Chroma Key to default
    Posted 01-18-2012 19:05
    What is the process to reset a Chroma Key to default?
    Thanks Les.
  • 2.  RE: Resetting Chroma Key to default
    Posted 01-18-2012 20:06
    Hold down the Chroma Key button (while looking at the correct keyer ;) ) and then press the Reset button in the keypad.
    If you have a 1M or 2M panel you will see the button mnemonic change to Reset.
