Dear Sir,
Knowing the Acuity have the split ME function with different keyer assign to different PGM output (PGM A & PGM B).
The Panel itself have two buttons " PGM A" & "PGM B" in the Transition module for control which PGM output buses....
Have assigned two ROW as first ROW is PGM A, second ROW is PGM B , which can make the signal selection & the transition separately...
However, while use second ROW to control PGM B, the first ROW will also change to PGM B...
It cannot be separated as 2 ME at the same time to control, isn't it?
Thanks & regards,
Jackie
