I have a Crossover Solo, and this thing is awesome. However, I'm having an issue with getting a still loaded from USB. I'm using a PNY 16GB USB drive formatted NTFS, and it only has two images on the root directory. Both of these are 32-bit .tga w/ alpha to be loaded into stills, which I will then key over (they're variations of live bugs).
Any ideas? My next step is to try a smaller drive (4GB or 8GB), because I've seen the same issue with our Vision, and wonder if the same thing is happening.
