  • 1.  Aux Bus Proc Amp / Color Correction
    Posted 10-21-2015 20:25
    Hello All:
    we are on version 12.1
    I want to color correct the output of an aux bus.
    We are in editor mode to use with OverDrive.
    It is my understanding if we have 4 MLEs, we should be able to color correct 4 aux buses.
    However when I double press a crosspoint on an aux bus selector - all options for color correcting are greyed out.
    There is a blank button where from the manual I would expect an "assign corrector" to be.
    The left side of the screen says
    Aux buses assigned to correctors: None
    What am I missing?
    Is this a possible software glitch - we are on 12.1f MD (a special version that added a CG timeout variable for some of our chyron graphics)
    Thanks,
    Clint
  • 2.  RE: Aux Bus Proc Amp / Color Correction
    Posted 10-21-2015 21:23
    Hi Clint you have to "enable" an ME or more to share the resources with aux buses. To do this you will be making Key 4 of that ME "Internal" and will only be able to access ME Stores -- If you don't have those then Keyer 4 will pretty much be turned off.
    Pick the ME that you want to use (I would pick the ME that you use Key 4 pretty much never on) and then in installation under Key 4 Config you can then assign that ME to be in a Mode that will give you these correctors. Also note that you will be using one of the Clean Feed paths as the means for this correction -- so if you have templates that use clean feeds for monitor fills then you will also have to make sure that you have not broken those.
    #Vision
  • 3.  RE: Aux Bus Proc Amp / Color Correction
    Posted 10-21-2015 22:01
    Thanks Les,
    Wow - I somehow missed all of that quickly looking over the documentation.
    We need at least 3 outputs to be corrected - I can't imagine giving up keyer 4 on all 3 M/Es to accomplish this.
    Thanks for the quick reply,
    -Clint
    #Vision
