I am, having a Smart converter problem as well. The converter seems to underscan sources brought into them. By underscan I mean when it calles up an SD ENG microwave shot, the smart converter will take the SD signal and upconvert it and strech it to 16x9. The top of the video signal. maybe 15 or 20 lines is black. I notive it when the video is Full screen. However when you put it in a split box it is very noticable.
The weird part is every so often it is not underscanned and teh video fills the screen compleatly. All of our converters are set the same and I can not tell that it is one certian smart converter acting differently than the others.
Any thoughts?
#Vision
