  • 1.  Image Sequence Animation
    Posted 01-11-2012 17:30
    I've created a series of Targa Image Sequences to use as media wipes on the Carbonite. When I load them into a Media Store Channel they show up as individual files, not as an animation.
    I created the files using Apple Motion and exported to a sequentially numbered Targa image sequence. Any ideas on what I'm doing wrong?
  • 2.  RE: Image Sequence Animation
    Posted 01-11-2012 18:23
    The issue you are having is that you probably don't have the underscore in the name.
    To signify a "sequence" the system is looking for Name_0000 so for example I would have my file named wipe_0000.TGA and then they go up sequentially from there.
    After you load it on the USB when the system "displays" it to you what is seen is a Single entry but with a [30] where 30 is the number of frames. So I would see wipe [30]
  • 3.  RE: Image Sequence Animation
    Posted 01-11-2012 20:12
    That fixed it! Thanks Les.
