  • 1.  Turning Off and ON Carbonite Switch
    Posted 02-18-2012 00:03
    Less can you explain what is the best method to turn on the Carbonite switcher and to Turn off.
    I ask you because sometimes I think that turning off in any form could damage the swithcer thinking in the electronics element inside of this, the Ram and software running inside.
    Explain what is the best method for both
  • 2.  RE: Turning Off and ON Carbonite Switch
    Posted 02-18-2012 00:36
    just turn them off ;)
    There is no moving parts like in a platter based Hard Drive like a PC so you will not not damage anything by turning off the power switch -- as a result we don't have any form of a "Menu Shutdown" command. In Vision we have this but that is because the Frame has a Hard Drive and we want to park it before cutting off the power.
