Is there a way to disable the switcher from going back to the state (toggling) it came from? I believe I do not have memAI turned on, it is not illuminated in the keypad area. Is there somewhere in the menu tree I am missing?
For instance:
I use ME/1 Emems to cut the show..... If I am in a replay on ME/2 and I select to go back to Cam 2 and then Cam 4 and I press the correct corresponding Emem
ONCE, all is fine. However, if I press Emem 4
twice either by accident or just press it for the second time in order (in my mind) too make sure I am going back to Cam 4. The switcher will go back to the Cam 2 selected state since that is the last camera selected before Cam 4 was selected.
