I'm on a Vision 3 and do not have a auxiliary control panel so I need to set this up in the soft panel.
I have never done this, this way so I need help.
What I need to do is send program feed less down stream key channel 1, but keep key channel 2 in the feed.
To date this switcher has never been setup for aux output feeds.
As far as I have gotten is:
I hit the select button next to the mnemonic window on MLE3
I see Select Aux Bus
now what?
