  • 1.  MLE Tally Question
    Posted 03-16-2012 13:59
    I have a 4 MLE Vision 2 - I set MLE 3 to Tally "on air" but it tallys cameras whether MLE 3 is on air or not. It acts like I have set it to "tally always." Any ideas?
  • 2.  RE: MLE Tally Question
    Posted 03-16-2012 14:10
    Serial Tally or Physical Tally from the Back of the Panel? Multi-Panel system or Single Panel?
    What version of software? Have you contacted Tech Support or sent them your Setup Files to check?
    #Vision
  • 3.  RE: MLE Tally Question
    Posted 03-16-2012 14:37
    Serial Tally - it is single panel with 3 panel rows. Running 14b Software. I will send setup to tech support to see if they can determine what the issue is. MLE 1 & 2 are set to "tally on air" and they seem to work correctly but MLE 3 tallys when it is not on air.
    #Vision
