  • 1.  Blinking led
    Posted 02-17-2014 16:05
    What does it mean when the center led is blinking?
    The LEDs are the one show beside the fader (handle) when you do a mixe/transition.
    The led at the very center is blinking on the MLE2 (the one for the program)
    Can we make it stop?
    Thanks.
  • 2.  RE: Blinking led
    Posted 02-17-2014 22:57
    Stephane, I am just another technical director using the switcher------
    I have never noticed the center LED blinking, and I will be on a switcher tomorrow and I can verify mine, however in the meantime.. You may want to try tagging all the sources, BKGND, KEY 1,2,3,4 all together then pull the T-bar from the top to bottom a couple of times. After doing so --- Untag all sources and see if it is still blinking, sound to me as if the switcher is thinking that it is MID transition on one of the transitional sources.
    Another thought - (again I have not paid attention to it) --- Put MLE1 on PGM and see if the center LED on MLE 1 illuminates. It maybe an indicator to which MLE is on PGM. I re-enter my MLE 1 into MLE 2 Keys and I have everything different colors, based on what is on PGM/PRE and re-entered.
    I'll load a default switcher setting tomorrow afternoon (cst) and check more if you do not replay to this post informing of a different status on yours.
  • 3.  RE: Blinking led
    Posted 02-18-2014 06:45
    Hi guys.
    You have trans limit enabled.
    In the menu when you have selected a trans type you will find trans limit enabled.
  • 4.  RE: Blinking led
    Posted 02-18-2014 10:15
