  • 1.  Using the Carbonite as a downconverter
    Posted 08-29-2013 18:34
    Is it possible to downconvert a HD 1080i signal within the mixer? My Carbonite is setup in 576i and I want to downconvert a HD camera source.
  • 2.  RE: Using the Carbonite as a downconverter
    Posted 09-09-2013 23:18
    Tobias, looks like your question went unanswered. My apologies.
    Yes you can downconvert HD to SD with Carbonite. Just go to the ref menu and assign the input to a Frame Sync /Converter.
    Sorry for the delay.
    Nigel
  • 3.  RE: Using the Carbonite as a downconverter
    Posted 09-13-2013 18:57
    Note, using the FSFC does add a bit of latency - nothing catastrophic but be sure to adjust audio delay for that particular input device as needed to compensate
