  • 1.  Button inserts - RCP-NK1
    Posted 02-15-2013 18:21
    I'd like to kwon how to remove the buttons cover to place the transparency printed inserts?
    Thank's
  • 2.  RE: Button inserts - RCP-NK1
    Posted 04-04-2013 13:20
    You must remove the front panel from it´s backplane with a flat srewdriver on both sides of the front of the panel, then remove the long bolt´s on the left and right side inside the panel, and then you can take out the inside of the panel.
    Then you can access the button´s by lifting the pastic hood´s from the button.
