  • 1.  How to create a 2, 3, 4 etc way box with push effect using sequence with QMD
    Posted 12-02-2014 15:04
    hi
    Can you tell me that how to create a 2, 3, 4 etc way box with push effect using sequence and if possible send me the video tutorial.
  • 2.  RE: How to create a 2, 3, 4 etc way box with push effect using sequence with QMD
    Posted 12-05-2014 19:46
    Hi Amit,
    I placed this video in another thread with you from a couple of weeks ago.
    https://www.dropbox.com/s/cp2vr2153aij0br/4BoxVideoSmall%20-%20Wi-Fi.m4v?dl=0
    #Vision
  • 3.  RE: How to create a 2, 3, 4 etc way box with push effect using sequence with QMD
    Posted 12-06-2014 03:56
    thanks les it really helps and also can i use the same effect using sequence because i wanna use them with the help of a sequence,
    Also i need to have a "L-Band Advertisement on my PGM so how can i create the sequence for that please let me know
    #Vision
  • 4.  RE: How to create a 2, 3, 4 etc way box with push effect using sequence with QMD
    Posted 12-06-2014 23:36
    Hi Amit,
    This is starting to look like you need some advanced training. I would recommend that you contact your Ross Sales Rep to have some onsite training booked so that we can deliver this first hand. This will ensure that you learn all of the aspects of these items in the switcher so that you can create these effects on your own.
    #Vision
