Need Upgrade Notes For Acuity 5.0
  • 1.  Need Upgrade Notes For Acuity 5.0
    Posted 07-17-2017 20:13
    Les:
    I have 4.0 and 6.0 upgrade notes BUT no one seems to have 5.0.
    I already have the Compact Flash OS...
    If you can send me the link or notes, it would be greatly appreciated!
    Sincerely,
    Fletcher G.
  • 2.  RE: Need Upgrade Notes For Acuity 5.0
    Posted 07-17-2017 20:20
    https://www.dropbox.com/s/d760c8j8lfprl1z/Acuity%20v6.0c%20Release%20Notes.pdf?dl=0
    The release notes are a running file -- This will have everything from the start to the present.
    #Acuity
  • 3.  RE: Need Upgrade Notes For Acuity 5.0
    Posted 07-17-2017 23:15
    Les:
    This is GREAT - and very much needed - BUT ([I]and you just knew there was going to be a "but" didn't you?[/I]) I need the actual "software upgrade procedures" which states things such as "Preparing the switcher before upgrade" and "performing the upgrade".
    Do you have that procedure for 5.0?
    Sincerely,
    Fletcher G.
    #Acuity
  • 4.  RE: Need Upgrade Notes For Acuity 5.0
    Posted 07-18-2017 07:40
    They are the same -- you save your stuff then do an upgrade :). I don't have the version 5 files I only keep the version 6 ones on my laptop.
    #Acuity
  • 5.  RE: Need Upgrade Notes For Acuity 5.0
    Posted 07-18-2017 16:28
    Les:
    I only have ONE QUESTION: When do you install the panel OS Compact Flash?
    Do you: [1.] Put in the Panel OS Compact Flash AFTER the Factory Rest BUT BEFORE the upgrade?
    [INDENT=2][2.] Put in the Panel OS Compact Flash AFTER the Frame upgrade BUT BEFORE the Panel upgrade?
    OR
    [3.] Put in the Panel OS Compact Flash AFTER upgrade BEFORE the system reboot?[/INDENT]
    I MAY be wrong but this does seem to be an important step, right? ;)
    Please let me know - by the way, the V4 upgrade process was pretty easy...!
    Sincerely,
    Fletcher G.
    #Acuity
  • 6.  RE: Need Upgrade Notes For Acuity 5.0
    Posted 07-18-2017 18:53
    I just did an upgrade today here in germany. To be honest I never factory default the switcher. I just upgrade it. You can upgrade the "Engine" but not say ok to a panel upgrade. Basically it sits there and says it needs to be upgraded and you don't have to do anything. Also you can just turn off the panel while the frame is upgrading and do the CF swap.
    #Acuity
  • 7.  RE: Need Upgrade Notes For Acuity 5.0
    Posted 07-18-2017 18:54
    Just make sure to write down your IP addresses for panel and frame as your going to need to enter them again with the new CF card.
    #Acuity
  • 8.  RE: Need Upgrade Notes For Acuity 5.0
    Posted 07-18-2017 23:10
    Les:
    It went pretty smooth. I loss my button color scheme but got it back once I turned the custom color scheme on....
    Respectfully,
    Fletcher G.
    #Acuity
  • 9.  RE: Need Upgrade Notes For Acuity 5.0
    Posted 08-01-2017 15:55
    So... Opening the front of the Acuity video rack, and I see no CF card slot. Do I need to pull out boards to access it?
    #Acuity
  • 10.  RE: Need Upgrade Notes For Acuity 5.0
    Posted 08-01-2017 16:18
    The CF card slot is in the Panel CPU sled. There is a door that can be opened to gain access
    #Acuity
  • 11.  RE: Need Upgrade Notes For Acuity 5.0
    Posted 08-01-2017 19:55
    Do you have a photo of that, when I open the front door of the rack panel there are no other doors on the inside and there is no visible CF card slot.
    #Acuity
  • 12.  RE: Need Upgrade Notes For Acuity 5.0
    Posted 08-02-2017 01:38
    It is not in the Frame -- IN the Panel. Lift the panel top and you will see the panel CPU SLED and a small plate/door with 2 screws at the front near the USB Port -- one of the ports has a cable that leads to the panel top USB port.
    #Acuity
