  • 1.  Still store Play command
    Posted 08-19-2015 13:25
    Hi, is there a way to send the play command to the still store for playing out a targa sequence without using a custom ?
    We want to use a bug (overlay graphic ) on the vision mixer but already need a custom to go to the camera with a certain video effect from a video server.
    with kind regards,
    sven
  • 2.  RE: Still store Play command
    Posted 08-21-2015 01:06
    Can the custom not be recorded to do both effects?
    #Vision
  • 3.  RE: Still store Play command
    Posted 08-21-2015 04:55
    The Still Store menu has a Play button.
    So if you press the Keyer Sel button that the bug is in it will bring up the Channels menu -- press play.
    If your looking for it to AutoPlay every time it goes to air -- you can always just set the Animation properties to have it set to autoplay.
    #Vision
  • 4.  RE: Still store Play command
    Posted 09-10-2015 14:40
    thx for the answers.
    I already knew that the menu had a play command,the operator just doesn't have the time to do it all at once..
    Maybe the autoplay will work.
    Sven
    #Vision
