  • 1.  Cache Full Error
    Posted 11-05-2012 15:32
    For some reason I keep getting a "Cache full error" when I try to load some GFX. I have also noticed that when I delete files from my USB the switcher still lists them when I scroll through the directory. I am using version 4.0.6.7278 on a crossover 16.
    Any ideas?...
  • 2.  RE: Cache Full Error
    Posted 11-06-2012 17:43
    Hi Jamie,
    the Cache full error will be with the fact that you have something in the channel that consumes enough frames that the item your loading would need some of. What you can do is load ID "0" which will eject the channel -- or just load a still into the channel -- also make sure that the associated alpha channel is not loaded with the original items frames of alpha.
    Yes when you delete them from the usb there is still an entry in the Database. if you click on it it will then ask you to confirm the removal of it from the database to free up that entry ID. Then it will be gone.
    #Vision
  • 3.  RE: Cache Full Error
    Posted 11-06-2012 19:12
    Thanks again for your response, Les.
    I cleared the media store channels by hitting M1-->000--> Select. I checked all 4 channels and they appear to be empty. However, I still get the error when loading an animation that is 200 frames totaling 326MB.
    #Vision
  • 4.  RE: Cache Full Error
    Posted 11-06-2012 20:40
    Maybe you could dropbox that animation to me and I will have someone take a look at it here.
    #Vision
  • 5.  RE: Cache Full Error
    Posted 12-04-2012 20:05
    Hi Les. Just wondering if anyone over there saw anything wrong the my animations. I am still not able to load the animation. Old animations that have since been deleted from my USB are still showing up and I don't get the option to " Free?" the entry. I just get the "Cache full" error message instead...
    Thanks for your help.
    #Vision
  • 6.  RE: Cache Full Error
    Posted 12-05-2012 16:37
    I though I sent you an email.
    The animation is not 326MB it is much larger as the file gets expanded into the full video space. This animation is over the 2GB limit.
    #Vision
  • 7.  RE: Cache Full Error
    Posted 12-10-2012 20:33
    Thanks, Les. You are a tremendous help. :)
    #Vision
  • 8.  RE: Cache Full Error
    Posted 12-13-2012 15:09
    Glad we could help you out -- let us know if we can do anything else.
    #Vision
  • 9.  RE: Cache Full Error
    Posted 04-12-2015 12:57
    Is there a way to calculate what the size will be once it's expanded? I have an animation of 206 frames that's getting the same cache full error. The folder's 1.7 GB on my desktop.
    #Vision
