  • 1.  GPIO of Carbonite
    Posted 09-01-2016 02:49
    When we set the GPIO interface as GPI input, is it a passive circuit or active circuit?
    When I send GPI trigger from external device to Carbonite frame, I should give it a contact closure or a +5V DC level?
  • 2.  RE: GPIO of Carbonite
    Posted 09-01-2016 03:24
    Depends I how you define the config of the trigger.
    Setting as a low and using A contact closure will work. Setting as a high will need a 5V level or trigger based on the settings.
  • 3.  RE: GPIO of Carbonite
    Posted 09-14-2016 05:18
    Thanks Les, it is working with contact closure now.
