Okay so CC would be Load Sequence (when recording type the number of the sequence into the keypad-- easier that way. Or have a Memory that already has the sequence loaded in it be recalled) Pause a couple of Frames. Then you Run the Sequence (there is an Insert Even - Special - Command for this). You now need a Pause of at least 1 Frame longer than your sequence. if the sequence total is 90 frames then make it 91. Now add the Insert Event - Special - Loop command. To "kill" the CC your going to need to either press the Stop Button -- if you assigned one. Or if not then press an "empty" custom control. That will kill all running Custom Controls.
#Vision
