I have been going over ver-11 many nice changes. I like the fact that you now can see what memories are being used. The problem is I do not see any way like in custom control to delete a memory so you can see it is empty and reuse it. Also is there any way to name the memories like custom controls?
I found in custom controls under create/edit event: SWITCHER INSTALLATION, ME, ME CLEAN FEED, there is only one selection. KEYER-1. How do you select other keyers?
