  • 1.  What Software version needed for Carbonite Switcher to work for UHD 4K?
    Posted 06-29-2016 02:35
    Hi Les,
    Can the Carbonite switcher work for UHD 4K in software version V10?
    Or need to upgrade to latest software version V12.0?
    Thanks & regards,
    Jackie
  • 2.  RE: What Software version needed for Carbonite Switcher to work for UHD 4K?
    Posted 06-29-2016 15:02
    The short answer is that v10 will work. However I would upgrade to v12 as there is a new option for the background to change how it uses DVE's. In past software version if you were using the MiniME's for UHD then it would set 4 DVE's for the background all the time, but in 12 you can turn it off or make it dynamic. Be sure to follow and read the instructions when upgrading to v12.
  • 3.  RE: What Software version needed for Carbonite Switcher to work for UHD 4K?
    Posted 06-30-2016 09:57
    Thanks for the answer. By the way, I'm now downloading the V12.0 software...but seems stuck on 1% and no processing... can you also help?
    Thanks form Jackie
  • 4.  RE: What Software version needed for Carbonite Switcher to work for UHD 4K?
    Posted 07-21-2016 08:44
    Finally can download the V12.0 software. Thanks!
