So just really quick response as I just saw this.
This product is developed by the same team and is built off of the same code base.
Due to many reasons we preferred the path of branching and starting with software version number 1.
There will be differences in product and features that are not going to allow common software version between the product so you will see it as different product download versions.
Ironically currently Solo has an advancement of the DashBoard interface with the introduction of the SoftPanel. This does require the use of 1920x1080 minimum resolution.
I have a Solo Walk Through video to cover all the menus mostly done. Need to finish some edits and then it will post to the Carbonite U section.
All Solo questions and comments should be posted here as this is a Carbonite Series product.
Thanks all!!
Looking forward to hearing from everyone what they are up to with their new Carbonite Solo switchers!! Already shipped over 140 units since its release a few days ago :)
