  • 1.  Xpression on Carbonite / Key Autoselect Transparent
    Posted 01-15-2017 15:02
    Hey,
    with the newest update i got an issue.
    The Xpression outputs FILL / KEY via SDI. Inputed to the Carbonite it looks fine.
    Once i want to key it with Autoselect - Clip Gain @50% and Transparent 0%
    This gives me on a Fullscreen gfx a non 100% correct keyed signal. its around 5 % transparent. if i turn the gain down to 44% its fine.
    I have noticed that the Fill in has a higher Blacklevel then 0%.
    Any idea where the issue comes from ?
    Xpression looks ok as the gfx where used last year and also older gfx that worked have this problem now. i recently updated the carbonite.
  • 2.  RE: Xpression on Carbonite / Key Autoselect Transparent
    Posted 01-15-2017 16:24
    Might be best to call tech support. Do you have a plus model? If so any chance you have a proc amp turned on the fill?
  • 3.  RE: Xpression on Carbonite / Key Autoselect Transparent
    Posted 01-15-2017 16:45
    Stefan, Have you checked that the alpha channel is correctly associated with the fill in the input settings? Also is the keyer set to additive?
  • 4.  RE: Xpression on Carbonite / Key Autoselect Transparent
    Posted 01-15-2017 17:20
    Hey,
    yes we have the plus model.
    i have no proc active on that inputs. yes the alpha is setup correctly. the keyer is set to normal but i tryed additive earlier as well.
    stefan
  • 5.  RE: Xpression on Carbonite / Key Autoselect Transparent
    Posted 01-15-2017 17:22
    The as Les suggested you should contact tech support, they are available 24/7.
