  • 1.  Additional GPIOs on Vision
    Posted 10-18-2017 03:48
    I'm using all 10 GPIOs. Any suggestions on how I could get more GPIOs out of the switcher? Or how I can toggle an external device without?
  • 2.  RE: Additional GPIOs on Vision
    Posted 10-18-2017 13:47
    What is the device? Also depending on the device it is possible to use the Tally connectors. You would just setup a Fake Aux Bus and Tally events for sources on that Aux Bus. Then you make CCs that will change the XPT on that fake Aux from Black - Source assigned to Tally for x number of frames then back to black again.
    #Vision
  • 3.  RE: Additional GPIOs on Vision
    Posted 10-24-2017 03:00
    Les thanks for the response. I am changing the source on an external monitor and I would like to use a GPIO to do it, if possible.
    #Vision
  • 4.  RE: Additional GPIOs on Vision
    Posted 10-29-2017 01:03
    So your using an external controller to trigger the switcher? Well you could enable RossTalk and then add some OpenGear GPI cards that would allow the GPI to be converted to a RossTalk Command.
    #Vision
