  • 1.  CC command to Eject Blackstorm cahnnel
    Posted 11-27-2013 22:24
    Is there any way to eject a Blackstorm channel using a command found in the Custom Controls>Insert Special>VTR section. I can't seem to find something obvious like 'eject'. Perhaps there is another way of achieving this.
    Thanks.
  • 2.  RE: CC command to Eject Blackstorm cahnnel
    Posted 01-26-2014 11:05
    I believe the "Stop" command will eject the current clip. Alternatively you could have your graphics folks work up a 2 second transparent/black clip and recall that clip as though it were an eject command.
    #Vision
  • 3.  RE: CC command to Eject Blackstorm cahnnel
    Posted 03-19-2014 09:41
    i thought the Stop command would eject the clip, as that is what i read in the manual. However, for some reason when i put a stop command in a CC, i still see tail end of the previous clip in the Blackstorm channel.
    #Vision
  • 4.  RE: CC command to Eject Blackstorm cahnnel
    Posted 03-19-2014 12:29
    https://www.dropbox.com/s/no4ee3al6p19qfh/Black.mov
    Use the above clip to load Black to the channel.
    #Vision
