  • 1.  Saving Memories from Switcher into Shot Box
    Posted 01-29-2015 22:08
    Does anyone know how to save memories from the switcher into the shot box? Or where I can get a manual for saving memories into the shot box? Thanks.
  • 2.  RE: Saving Memories from Switcher into Shot Box
    Posted 01-31-2015 18:53
    Manuals are on the Website under the Carbonite section. Here is the link that you would find on the site:
    http://www.rossvideo.com/pdf/manuals/carbonite/Carbonite_v10_0_Manuals.zip
    Now as for other items for learning how to store memories -- see the Carbonite U section.
    http://www.rossvideo.com/production-switchers/carbonite/carbonite-u/index.html
    Video 104 is all about Memory Store and Recall.
  • 3.  RE: Saving Memories from Switcher into Shot Box
    Posted 02-03-2015 00:14
    Thanks Les, but I looked in the manual and all it said was refer to the manual that came sideshot, shot box. Where might I find that manual? apparently someone said that ross tech support would beable to remotely go into our system.
  • 4.  RE: Saving Memories from Switcher into Shot Box
    Posted 02-03-2015 01:35
    Oh your talking about the "external" Shot Box.
    Well that is fixed to the 4 Banks of Custom Controls with the first 24 Customs per bank. So you would want to watch the video 108 about building Macros. That will show you how you build a Custom Control to run events -- Including State Based or Event based.
    http://www.rossvideo.com/production-switchers/carbonite/carbonite-u/video-tutorial-108.html
  • 5.  RE: Saving Memories from Switcher into Shot Box
    Posted 02-03-2015 03:38
    Hi Les,
    so that would be able to save shots in the "external shot box"?
  • 6.  RE: Saving Memories from Switcher into Shot Box
    Posted 02-03-2015 16:28
    Noah,
    The "ShotBox" is just a "pointer" to the custom control. You don't actually store the information in the module. When you build the Macro and Name it you will now get that on the pre defined button in the Shot box for that Custom Control.
