We just started using a hard bottom edge on some of our image store keys. Generally they are an image sequence of 1920x270. I try to position them all the way to the bottom of the frame and they are still a pixel row above the bottom of the frame. This error also shows up in single images, but NOT in full frame images, just ones using the position function. Attached are 2 shots of a monitor showing the error, a solid bar I used for testing, and an example of the actual key we're trying to use.
Vision 17.0M
1080i 59.94
