  • 1.  Custom control timing differences between formats
    Posted 01-23-2017 17:12
    We recently changed our format from 1080i to 720p. I've noticed that the timing on some of our custom controls seems "off". (We were using a 720p graphics package before, along with the Carbonite's FSFC's to convert to 1080i.)
    Is there a multiplier that I can use to convert the delays between the two formats, or do I just need to feel everything out again?
  • 2.  RE: Custom control timing differences between formats
    Posted 01-23-2017 17:23
    1080i is 30 frames (59.94 Fields) per second. 720p is 60 Frames (59.94 Frames) per second. Just double up your Pauses and then "fell" a couple of them out. The FSFC was adding 1 frame of delay to the graphics so you may have to remove a frame or 2 from the overall total due to that.
  • 3.  RE: Custom control timing differences between formats
    Posted 01-25-2017 05:25
    Thanks Les. Doubling my timings seems to have done the trick.
