  • 1.  HD output multiviewer
    Posted 02-15-2013 09:30
    We do have a vision2 with HD option but we do have only SD inputs and outputs.
    We do have a multiviewer option but this output is still SD can we set the multiviewer output to HD and use the vision as a SD mixer?
    Greetings Gerrit Meijering
  • 2.  RE: HD output multiviewer
    Posted 02-16-2013 20:56
    Hi Gerrit,
    You can not have the MultiViewer in Vision operate in HD when the system is in SD. The MV has to follow the system format.
    #Vision
