  • 1.  CamBot Control through Vision
    Posted 09-09-2014 17:07
    Our shop just installed a Vision w/ Version 17.0e.
    The CamBot Controls are backwards when I try to adjust a shot through the Vision. When I move the joystick to the right, the camera pans left, and vice-versa.
    I have a feeling it is just a setting that I'm overlooking.
  • 2.  RE: CamBot Control through Vision
    Posted 09-09-2014 17:34
    Hi Nate,
    use this config document -- you use the extra options to use the "invert" for Pan and / or Tilt
    http://www.rossvideo.com/pdf/cutsheets/vision-interface/robo-cam/Robo-Cam_Ross%20CamBot%20(4999DR-096-04).pdf
    #Vision
