  • 1.  Shaping Boxes
    Posted 10-25-2016 19:47
    I'm trying to shape a box to a sort of parallelogram to fit with a box graphic. Using DVE > Position/Crop I can get it really close but I can't seem to ever have it properly over the graphic. Any advice would help!
  • 2.  RE: Shaping Boxes
    Posted 03-19-2021 15:14
    Split Key?  If you have the Shape you can load a Black/White "Alpha" essentially of the shape into a still store to create the shape then squeeze down the box....  If you don't have the Shape you can use a bunch of Keys and Patterns to "create" the Shape and then capture it into the still store.
    #Vision
