  • 1.  Custom Control controlling Dashboard Custom Panel GPI Trigger
    Posted 01-25-2017 22:23
    I'm trying to get a custom panel to be able to be fired by a custom control. I've setup the GPI 3 to be record on and GPI 4 as the other. I've setup the xpression ross talk language as a device on the carbonite. I can control deck from dashboard custom panel. This is what I did for custom control. It just isn't talking.
  • 2.  RE: Custom Control controlling Dashboard Custom Panel GPI Trigger
    Posted 01-25-2017 22:40
    1 -- Did you enable the Global Listener in the DashBoard Preferences?
    2 -- You still need to assign the device to a XPT if you have not.
  • 3.  RE: Custom Control controlling Dashboard Custom Panel GPI Trigger
    Posted 01-26-2017 16:42
    1 - Yes
    2 - I have one other instance of xpression controlling something. If it is controlling Dashboard, do I have to assign it to an input? Is that what you are referring to? I created it in the carbonite.
  • 4.  RE: Custom Control controlling Dashboard Custom Panel GPI Trigger
    Posted 01-26-2017 16:47
    Yes you have to assign the Device to a crosspoint -- does not matter what crosspoint just pick one (there is a Bug not sure when/if fixed yet that if no XPT assignment is made the CC won't actually send out the message).
    Next/New Question based on your mention of xpression controlling something -- Are you sending commands to "two" things that are on the same Computer. As in are you sending RossTalk to XPression and DashBoard that is on the same PC? If so have you assigned a different IP PORT? You can not have both connections to the same IP address trying to use 7788. You would want to change the DashBoard to 7789 in the switcher config and the dashboard listener config.
  • 5.  RE: Custom Control controlling Dashboard Custom Panel GPI Trigger
    Posted 01-26-2017 18:49
    No. Just dashboard. Another computer is receiving xpression commands for 3rd party setup
  • 6.  RE: Custom Control controlling Dashboard Custom Panel GPI Trigger
    Posted 01-26-2017 19:33
    Do you just mean connecting it to an input on the carbonite?
  • 7.  RE: Custom Control controlling Dashboard Custom Panel GPI Trigger
    Posted 01-31-2017 21:31
    I attached it to an input, but nothing. I've assigned xpression to a device before and did the same way. Is there something I'm missing?
  • 8.  RE: Custom Control controlling Dashboard Custom Panel GPI Trigger
    Posted 02-01-2017 03:25
    I would like to see the dashboard panel and also the switcher configuration files -- can you send those to me? Loreilly@rossvideo.com.
    Also you don't have the firewall enabled do you?
  • 9.  RE: Custom Control controlling Dashboard Custom Panel GPI Trigger
    Posted 02-08-2017 20:19
    Sorry, just saw this. Emailing you now.
