  • 1.  Multiscreen Mode__ - DVE
    Posted 02-02-2015 15:56
    Hey,
    i'm owning a Carbonite + with and 2S Panel.
    When I'm setting up an Multiscreen Setup over 3 MiniMe's i works ok. Whenever i setup an DVE and put that for examble in the middle it also works.
    when the dve is on at the minimes it doesnt allow me to use dves on MLE1 / 2
    any idea why ?
  • 2.  RE: Multiscreen Mode__ - DVE
    Posted 02-02-2015 17:09
    Hi Dirk,
    3 DVE are being used for the background and 3 for the DVE box. So you only have 2 left.
  • 3.  RE: Multiscreen Mode__ - DVE
    Posted 02-02-2015 21:32
    ok - as is understand it right - the 3 for multiscreen 3 for the dve i used and i should still have 2 left.
    i cant use any dve then whenever the dve is on at multiscreen
  • 4.  RE: Multiscreen Mode__ - DVE
    Posted 02-02-2015 21:37
    Check then to make sure that you don't have them being used somewhere else.
    Turn the MS off for Both MS1 and MS2. Then turn it back on for MS1.
    Then see if it is still locking out the DVEs
