After we investigated the images here we were not able to find out what was wrong with the image. However it would not load in a switcher.
If I duplicated the file and saved with a new name via Preview it would load fine.
After downloading the current version of Graphic Converter (v 8) I was able to take the original BMP file and do the size conversion and save the file as a TGA. This loaded fine into the switcher as well.
With that we were able to determine that there is something that the version that Jim had was doing something to the file that the switcher did not like. He will be upgrading to the current version.
#CrossOver
