Hi Les, before I set the CC, I should create a VDCP control port, what server type I should select?
The customer is running with Vision v17.0i. There are SMS4.3, Blackstorm for selection.
I have tried SMS 4.3, it seems not work. I have tried Blackstorm, it works for controlling play out channels, but not success for Rec.
Blackstorm does not have recording channel. will it be the reason of missing recording VDCP code?
There may have another reason that we don't the channel # of the XPression Rec.ch. Do you have any idea?
#Vision
