  • 1.  Loading Disk Set Wipes Vision's Sequences
    Posted 03-02-2016 15:17
    Over the summer our station got an upgrade to Vision software version 17.3 where we were at version 14.1 before. Ever since that upgrade whenever I load a current disk set none of the sequences load so I have to load an older sequence from a past disk set to get them back. Any ideas how I can get the sequences load from a current disk set?
  • 2.  RE: Loading Disk Set Wipes Vision's Sequences
    Posted 03-03-2016 01:09
    Have you tried to load that old sequence file and then just save that sequence file back over top of the current setup that you want to use? Have you tried saving to another location that is empty everything and then seeing if it is okay (doing this after you have loaded the old sequences that work over top of the current not working ones?)
    #Vision
