  • 1.  Bus-linking?
    Posted 11-16-2015 01:13
    I've been asked to build a scenario that I could tackle a couple of different ways, but one of the easiest would be if I could bus-link MLE-1 PGM to MiniME-1 PGM, and MLE-1 PVW to MiniME-2 PGM. As I looked through the panel menus and through Dashboard, I haven't seen anything like bus-linking ... I just want to make sure I'm not missing something? Full disclosure, my client is still using V9.1.0.
  • 2.  RE: Bus-linking?
    Posted 11-16-2015 14:42
    There is no full system Bus Linking. You can only link MiniME via MultiScreen and then do a Source Substation so that they select same or different sources and don't scale the image. This however does not help with the ME 1 PV request as the MiniME don't really have Preview.
    Even in version 11 there is no Bus link feature like you are looking for -- you would need a Vision or Acuity for that.
  • 3.  RE: Bus-linking?
    Posted 11-16-2015 15:17
    Thank you for the quick response, Les. I can do what I need to with Custom Controls and some XPT holds and effects dissolves on emems. In the end, I need to be in a 2-box effect that will have 2 channels of CG as an overlay. I need to be able to cut sources in both boxes, and also need the ability to pull either box full.
    Another thought was to loop 2 AUX outputs back into the switcher as sources, then (with proper next transition selection) I could potentially feed MLE CLN to one box, and MLE PVW to the other box -- this could give me the ability to cut in each box with the buttons on the panel, and best case, I could still keep my keyer row delegated for CC execution.
  • 4.  RE: Bus-linking?
    Posted 11-17-2015 00:42
    Hi Matt,
    The switcher supports a function called Aux Follow. You can map Aux Buses to the Bus Map as "inputs" then instead of doing a physical loop back just select an Aux to "follow". Then switch on the Aux and it will change the source in the box.
    In version 11 you can do a DVE in Both Keys of a MiniME Then loop into another MiniME so that you can Have an Overlay on top of them.
