  • 1.  Assigning Still Store images to AUX Buses
    Posted 11-11-2017 22:49
    Hi all,
    Just curious if someone could lead me in the right direction of assigning a Still Store image to an AUX Bus. I'm trying to be a "fail safe" button so if for some reason we can't feed any monitors with the desired graphics, there's a quick Custom Control that will bail us out in case of an emergency.
    Thanks for any/all help. Take care!
    ~Sean
  • 2.  RE: Assigning Still Store images to AUX Buses
    Posted 11-11-2017 23:28
    First I would use a Key Row on the panel to setup for that Aux Bus -- press the MLE SEL button just over the Key Bus of that Row. Now select the Aux Feeding the Display Monitor.
    Now Start Recording the Custom Control
    Select the Global Store channel you want to use now.
    the menu should have followed to the GS menu -- Now find the Graphic and load it into the channel.
    Stop Recording the custom control.
    #Vision
  • 3.  RE: Assigning Still Store images to AUX Buses
    Posted 11-11-2017 23:44
    Hi Les,
    Thank you so much for the speedy reply. You are awesome, sir! :)
    ... I was on this track but erred somewhere along the way. I'll try again tonight. Curious, what if I wanted to feed another source into an AUX Bus, using that same Custom Control? Is that possible.
    Thanks again for the help. Take care, sir.
    ~Sean
    #Vision
  • 4.  RE: Assigning Still Store images to AUX Buses
    Posted 11-12-2017 03:14
    ... Never mind. I figured it. :) Thank you so much for all the help, sir! Your tips were invaluable.
    You guys at Ross are amazing!!
    #Vision
  • 5.  RE: Assigning Still Store images to AUX Buses
    Posted 11-12-2017 23:15
    Glad to hear you got it sorted out. I was travelling today so just getting to a computer now.
    #Vision
