Is the MLE on air? If the MLE is not on air then you won't get the "roll"
You can also make the MLE "always on-air" in the installation menu -- outputs -- more -- MLE Tally. So if your using an Onset monitor feeding from a MLE you can make that MLE All Ways on air -- it will also help since then your sources will tally as well.
#Vision
