  • 1.  Vision reference
    Posted 04-22-2013 15:22
    Is there anyway to adjust the the H and V phases in the output of the Vision switch?
    I am running Vision software 12.1a
  • 2.  RE: Vision reference
    Posted 04-22-2013 15:56
    Hi John,
    No the Vision Output is locked in relation to the incoming Reference Input.
    If you want to be able to swing the output you will need to add a Frame Sync downstream of the switcher
    #Vision
