How do you crop a dve key then position effect using joy stick?
  • 1.  How do you crop a dve key then position effect using joy stick?
    Posted 09-20-2016 20:25
    I have a full screen image that i want to crop and position on key 3 me-3.
  • 2.  RE: How do you crop a dve key then position effect using joy stick?
    Posted 09-20-2016 20:36
    Position first then crop.
    The idea is that you crop to the bounds you don't want the image going beyond. Then your able to position and size in that region.
  • 3.  RE: How do you crop a dve key then position effect using joy stick?
    Posted 09-20-2016 23:06
    Thanks Les. See you Monday
  • 4.  RE: How do you crop a dve key then position effect using joy stick?
    Posted 09-21-2016 07:02
    Tuesday :) I fly in on Monday.
