  • 1.  Floating Warp License on Acuity
    Posted 11-27-2014 18:24
    Hi Les,
    Will it be possible to float warp license over all MLE's on the new Acuity frame?
    Starting from a 4 MLE configuration, all 4 MLE's with Warp license, will it be possible to configure 4 key's with 3D DVE's on one MLE?
    Jef
  • 2.  RE: Floating Warp License on Acuity
    Posted 11-28-2014 19:06
    They are physical cards that plug into the MEs. However similar to Vision MEs will be able to share with adjacent MEs. This means that ME 1 and 2 will be able to share their 4 channels (each channel also has alpha so you use 1 channel for any key type).
    So for 4 Keys with a 3D channel you would only need to have 2 MEs of resource shared between them.
    #Vision
