Yamaha tells me the MIDI setup is the same on the CL5 so it should work but we have not been able to do it. We have a DeviceMaster RTS-1 to convert the TC/IP data to RS-411 and the Ross SMC-9901 Serial to MIDI converter. The DeviceMaster setup is very complex and not documented for setup between Carbonite and the SMC-9901 so I've never been able to tell for sure if we were actually getting valid MIDI data to the mixer. Any suggestions would be appreciated.
