Dashboard does what you are looking to do.
Fastest way to copy files between sets is make your main set. Then re-save it as another name. Then modify the parameters you want to and re-save the set that you modified.
Each SET has 8 banks of custom controls, for instance I build my shows:
Bank one is normal score-bug in and out of replays.
Bank two is a copy of bank one with the replay changing the score-bug to my clocks cutout with the switcher and inserted into the score-bug.
Bank three is CG2 being used as the score-bugwith the clocks cut out by the switcher and inserted in the CG2.
Bank 4-7 are generally not used, but if I do then I put 2 boxes, 3 boxes, 4 boxes, 5 boxes, split screen, still store (media player recalls) of different backgrounds.
Bank 8 is the same as Bank 1 but omitting any type of score-bug.
I quickly copy Bank 1 custom controls to the other Banks as described above via
DASHBOARD then modify the replay out moves on Bank 2 and Bank 3 respectfully.
However you decide to do your workflow --- SAVE SAVE SAVE your set after modifying
