  • 1.  Custom control for aux
    Posted 01-25-2015 03:19
    In the switcher Vision I'm trying to create a custom control that recall an Aux with a source. Can you send me a how to instructions. Thanks
  • 2.  RE: Custom control for aux
    Posted 01-26-2015 03:11
    Before Recording the Custom Control Assign the Aux Bus to the Panel Row. To do this in the ME that you want the Control of the Key Bus to be delegated press the ME SEL Button. This button is on the Right Most XPT Module next to the Display that shows you the ME and the Keyer Priority/Assignment settings.
    Now in the Display you can pick the Aux Bus using the menu system to select the Aux Bank and Aux Bus.
    Now that you have the panel ready -- Start your custom control (or insert via the edit menu in an already recorded macro at the point you want the bus selection made). Now that your recording just select the XPT that you would like to switch to on the Aux. Now finish recording.
    if you look in your CC via the Edit menu you will see that the AUX XPT select has been added/inserted in the Custom Control.
    #Vision
  • 3.  RE: Custom control for aux
    Posted 01-26-2015 16:56
    Does this follow by XPT or by BNC based on the map?
    For example, if I were to have this put BNC C-01 into Aux 1, which is on button 2 of the bus map, then change the bus map so that C-01 is on button 3, will the custom control still work? Or will it attempt to grab whatever is on button 2, still.
    #Vision
