  • 1.  Linking PST Pat and Chroma on one key layer
    Posted 12-08-2017 20:42
    I think the trainer showed us this when he was here. We have a chroma layer on Key 3 and we also want to adjust the image as you would a PST Pattern. I thought he linked these two functions onto one key layer.
    Can anyone confirm if this is possible? If so, how to achieve this?
    Thanks for your help
    Mike
  • 2.  RE: Linking PST Pat and Chroma on one key layer
    Posted 12-22-2017 17:50
    You can apply a Pattern Mask to the Chroma Keyer. So in the Keyer Control Menu you have to enable the Mask then use the Pattern Generator instead of Box Mask option. Now you can adjust the pattern settings your applying.
    #Acuity
