  • 1.  Adding NDI sources to Dashboard
    Posted 08-17-2017 23:57
    How can you add NDI sources into the carbonite switcher? I see NDI is used for Expression, and I don't see how to add that as a source. Where can I find more info on NDI and Ross?
  • 2.  RE: Adding NDI sources to Dashboard
    Posted 08-18-2017 04:36
    You can not input an NDI source into Carbonite without using a Gateway. You will need an NDI to SDI gateway.
  • 3.  RE: Adding NDI sources to Dashboard
    Posted 08-22-2017 14:22
    NDI to SDI Conversion:
    For Mac: http://www.sienna-tv.com/ndi/ndi-outlet.html
    For Windows: https://www.newtek.com/connect/connect-pro/
